Originally posted by sesnopro
take of the sway bar
HUH? Thats the WORST advice I have hear on here in a while. Taking off the sway bar will make it MORE TIPPY. *shakes head*
To answer the original post....
I am surprised that you are having a serious ammount of inside ski lift on a ZR/ZL chassi sled. I would guess you are not leaning at all on the sled? All sleds have some inside ski lift if you do not ride them correctly... some more then others of course. I have never been on a flatter sled then the ZRT or ZR series sleds. I used to think my Ski Doo handled great... untill I bought a cat. If you want to try adding the rear to front coupling blocks it may help you out. You can either purchase an aftermarket kit or ones from cat. These kits limit how far the rear link falls forward when the suspension travels through its travel. When you install these kits it puts more preasure on the ski's instead of allowing the skid to cycle rearward and take preasure off the front. You can also try sucking up the limiter strap too.
