if you checked the voltage at battery when running , Make sure you check it also at a little higher rpm 2500-3000 , that is when the voltage will climb & blow bulbs, it will keep climbing as rpm get higher, If it stays at 14v to 14.2 or so at higher rpms the charging voltage is fine, check it the same way at a lighting plug (headlight or taillight) if its climbing at that point ,it should have a lighting regulator. you can check voltage coming out of a lighting regulator & should never get to 15 or 16 volts.
If it aint that green, It aint that mean!
