Old 12-08-2005, 09:32 AM   #1 (permalink)
JMM
Jag Suspension/shock
I am restoring a 1990 Jag AFS. All the springs, bushings, wheels etc look to be in good condition. I have greased all the fittings. When I compress the back of the sled it stays down. When I pick it up the track will drop back into position. I am assuming I need a new shock? The shock is a cartridge only, no coil spring. Thanks.
JMM is offline   Reply With Quote
Old 12-08-2005, 09:54 AM   #2 (permalink)
wornknobby
Ol' Skool Racing ASC
wornknobby's Avatar
yea, sounds like your rear shock is blown.
90' CR 125
2x 89 Cougar 500's
86 1/2 Nissan 4x4 shortbox
-posi locked
-31's
2x 91 Honda Accord's
wornknobby is offline   Reply With Quote
Old 12-08-2005, 03:35 PM   #3 (permalink)
JMM
Thats what I figured. I just ordered a Kimpex Gold, hopefully thats the ticket.
Old 12-08-2005, 07:28 PM   #4 (permalink)
rgoers
rgoers's Avatar
Wait, when you push it, it stays down? That would be the spring, wouldn't it??? The shock just provides damping, not rebound. If the spring is broken or missing, it would not return the skid to it's "home" position. The shock just damps the travel.
I usually test shocks by compressing the skid (stand on the seat?) and then releasing (jumping off suddenly). If the skid slams back up, the shock is shot. If it glides back up, it's good. Same on the down stroke. If it goes down too easily, the shock is bad.
From your description, I'd say spring, not shock. and I realize you said the shock does not have a coil spring on it. There should be other springs in the back that keep the skid "sprung" for lack of a better word.
2000 440 Panther
1980 Jag 3000 F/C
Old 12-08-2005, 09:36 PM   #5 (permalink)
JMM
Maybe both shock and spring? When I push down it goes down pretty easy and STAYS there. The sleds (I have two of the same) both do this. They have 1000 miles each. The springs look ok, I'll have to look closer. I am familiar with motorcycles and coil over shock, but this spring with seperate damper is strange.
Old 12-08-2005, 09:51 PM   #6 (permalink)
sesnopro
four gear pinned
sesnopro's Avatar
You are probly right, hyd shox work differently than gas. in newer shoxs gas rebounds, in older suspension(hyd) the shox was just a dampener for the springs.
http://www.hiperf.com/
Old 12-09-2005, 08:36 PM   #7 (permalink)
rgoers
rgoers's Avatar
The shock looks to be hydraulic, which means it does NOT rebound on its own. The springs (#7) are what provide the rebound. The adjuster blocks (#22) adjust the tension on the springs.
Hope that helps.
2000 440 Panther
1980 Jag 3000 F/C
Old 12-12-2005, 02:15 PM   #8 (permalink)
JMM
Yes that helps. It seems to working better after some light riding. I noticed if the sled is level (skis and track all on the floor) it seems to work ok. If the skis are up on the dolly and the track on the floor it seems to compress and not rebound. When done riding the back is iin the up position, so I guess thats ok.
