Old 11-29-2005, 10:38 AM   #1 (permalink)
JoeZR600
D&D PAC AND FUEL pressure regulator
Anyone use the D&D efi PAC and FUEL pressure regulator on there sled. Just wondering how its works with tuning for pipes.
JoeZR600 is offline   Reply With Quote
Old 11-29-2005, 12:34 PM   #2 (permalink)
sesnopro
four gear pinned
sesnopro's Avatar
they work asome, there are alot of companys making regs now. boondocker makes one with a analog screen, bikemann also makes one. you can just turn a dial and that will tune your fuel pressure. on the boondocker it does it through the computer.
http://www.hiperf.com/
Old 11-29-2005, 01:38 PM   #3 (permalink)
JoeZR600
I'm wanting to buy some pipes. But i'm wondering if the Fuel pressure regulator is enough to tune for pipes or do I need to get the PAC system too.
Old 11-29-2005, 05:59 PM   #4 (permalink)
sesnopro
four gear pinned
sesnopro's Avatar
I know with bikemann all you need is the reg b/c its got a gauge right on it. I dont thing D&D is any different.
Old 11-29-2005, 06:13 PM   #5 (permalink)
JoeZR600
I called around and did some research. The fuel regulator is a cheap way out. You can either richen or lean the fuel accross the entire rpm range. With a Boondocker kit or the Speedwerks EFI jet kit you can richen or lean the fuel at different rpms. Thats what I need. I mean, the fuel pressure regulator will work, but I dont want a heavy rich spot in the mid range. So, I talked with the guys at speekwerx and i'm going to buy one of there EFI jet kits.
