if you running an air box i think its practicaly impossible to suck in enough so to do that, cause the air comes theough the gap in between the fairing and body plasic arounf the steering colloum, through a fitting into the air box tube, then through the chambered air box. by the time that much snow got in it should of just satrved itself for air.
my best guess for bending rods is a bearing that went suddenly, mabee from some machining problems or somthing, either way find out whats doing it before putting it back together again.
also, if you happen to have any extra motor parts to get rid of or hav conections to somone with a motor or motor parts shoot me a pm, last year i put a new stator in about 5k befor i broke a skirt off the piston, broke the mathin cylynder piece to a skirt(right at the bottom, that dropps down) off, and put it out through the bottom, but what i dont get, is the fact i shut it off, it didnt die.
thanks and good luck
